Old 11-03-2016, 05:24 PM   #1
Gelbster
Originally Posted by bwdz View Post
You could just save the 2800 and do it over a weekend, these things are super easy to work on it actually blows my mind that shops charge more to work on the best engineered cars as they are so much better to do than a Dodge or a Taurus etc..
Those of us who have had to R&R + rebuild (not refresh) an M96 would love to learn your secrets that make it so easy AND FAST. I could not find your build thread......
Let's start with your speedy method of measuring the cylinders for ovality and taper ? The precision required for a meaningful assessment is +/-1/10 of 1 thou." You need to measure at exactly the same point in least 3 positions x 3 depths of all 6 cylinders ,replicated 3 times with no significant variation in measurement at a constant temperature. But you knew that .
This is almost FAA standard of work that is required on the M96.
Really , I am all ears because rebuilding an M96 correctly is a daunting ,expensive task for the few of us that have done it.The special M96 tools cost as much as an entire used Ford engine!
Do it sloppily and you'll need to rinse and repeat with a re-buy on many of the parts and most of the machining. Suggesting it is easy and fast may mislead some into a huge waste of time and money. That would be unkind.
Even replacing an IMSB has 19 pages of single spaced imperatives to follow.But you know that ?
