Old 10-28-2016, 01:08 PM   #1
Coaster
Coaster's Avatar
climate control buttons don't work?
Some of the AC control buttons don't seem to be working, particularly the down buttons for the set point and the fan. I can raise the temp but not lower it. The fan starts out at one bar and automatically raises to full fan within a min or so. I can't use the down button to lower the fan setting. The side buttons all seem to be fine. It appears to me the fan up button is stuck but that doesn't explain while the temp down button isn't working. It's possible some condensation from a drive thru drink dropped from the cup holder onto the face of the unit.
Is it easy to pull the unit and take off the face and clean the buttons? Any other suggestions?
Also, the display is missing some lights on the temp side, and there is a kit on Pelican Parts for repair. Does this fix the issue?
Climate Control LCD Panel Repair Kit, Porsche Boxster & 996
Part #: SIC-653-101-10
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is online now   Reply With Quote
