14mm will look really odd in the front. stick with the 7mm spacers in the front. not that the car even needs front spacers. i have 7mm h&r spacers on the back and they are perfect, with my set up. 275 / 30 / 19 rear and front 235 / 30 / 19 front. with this set up i feel no need to add a front spacer. no need. i only added a rear spacer because my rear rim was a 10.5 width and i needed to clear the rear strut, cause i was touching it.
why is it that you want to put a spacer on the front? esspecially 14mm.
