Old 10-24-2016, 05:04 PM   #11
madmodz
madmodz's Avatar
Originally Posted by Ben006 View Post
the code came after the plug change right ?
Make sure you have a spark on cylinder number 6.
If you removed the injectors, did you change the seals?
One thing you can do is swap the plug/coil or injector (one at a time) from cylinder 6 to another and see if the code moves to that cylinder, once it moves, you've found what is causing the trouble
Yes, put new seals on the injectors, but had no ideal if they are balanced.
After I put back on the intake manifold, it wouldn't rev right. I was thinking I had a fowl plug. This was before I added your plenum, so I know that's not the issue. Tonight Im pulling the whole sides coils off and pushing them back in.
To check for spark, I put the plug in the coil and ground it while trying to start the car right?
madmodz is offline   Reply With Quote
