On a 2003 oil leaking out around the spark plugs can be a expensive repair!!! Minimum the valve cover has to be removed and new seals installed between the tappet carrier and the valve cover. Worst case the cams and tappet carrier have to be removed and new seal and orings installed. The latter would require dropping the motor.
