Car is on flat ground when parking.
Ok this is what happens. I went to verify it again.
When Park is engaged.. I would let go of the brake pedal, and the car would rock gently back and forth for about 1-2s.. then stay stationary.
Sounds like a transmission problem?
They told me atf was flushed through and through. And i actually witnessed them removing and replacing the atf multiple times until the last output was clear atf fluid.
Sent from my Mi 4i using Tapatalk
