Old 09-25-2016, 09:49 AM   #5
JFP in PA
Well didn't think this would happen.....but. Yes it will fit . Here is a link to my conversion. Just need the bracket from Woody if you want it to look completely stock. Have fun. I really like mine.
S muffler on 98 base?
I'm still not convinced; if you look in the Porsche parts list for the U shaped connector pipes (#18 in the diagram) that go from the muffler to the cat pipe, you will find that the S pipe is a different part number than the 1999 base pipe. You would also find that all the parts for the base cat pipe (#5 in the diagram) are smaller in diameter, all the way to the triangular gaskets where the cat pipes bolt to the manifolds.
