Old 09-22-2016, 06:01 PM   #4
steved0x
steved0x's Avatar
I used this process when I replaced my shocks. It is a lot of work but in my opinion doable by a regular person and I am the proof
Hardest part was removing the rear LCA ball joint from the wheel carrier. If I had to do it again I would try leaving that connected and remove the other end (where the rear camber is adjusted) and see if that would work.
