Old 07-05-2006, 06:45 AM   #3
insite
sounds like my car when the MAF went bad. unplug the MAF and go for a drive. if the problem goes away, you have found the culprit.
btw - who did the tranny flush / fill? you trans has hypoid gears; if they used incompatible fluid, the shear from the hypoid cuts will degratde the viscosity of the oil.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
