Old 09-11-2016, 05:04 PM   #2
Meir
1999 base
Meir's Avatar
99% of the time, the problem lies in alignment between the transmission spline and the clutch friction plate. Make sure the friction plate is properly centered.
If you are using the plastic alignment tool, use also your vision to confirme it is centered. Put the transmission in gear, and turn the axle hubs a little bit at a time , while you are pushing in the transmission towards the engine.
Hope it helps.
