GBox needs to give you the tech advice on this, not us !
For example, you need to examine the input shaft for wear/marking where the lip of the seal fits.If there is any discernible marking ,discuss with GBox because fitting a new seal may be futile.
If the marking is slight, can it be 'improved' ?
If it can, is it possible to fit the new seal to a slightly different depth ? GBox to advise.
Similar issues arise with the RMS and sometimes experts(not me) suggest setting the new seal to a different depth to avoid repeat leak problems.
Let us know what happens?
