Old 09-02-2016, 08:34 AM   #19
Meir
1999 base
Meir's Avatar
Originally Posted by Need_for_speed View Post
I'm going to try and help him troubleshoot his P0507 code this weekend. I thought I'd take a crack at it before we take it to my indie. My hunch is vacuum leak, which will be tough to find without a smoke machine, but thought I'd look to see if there's anything obvious. I'm suspicious of the brake booster hose.
If anyone else has experience tracking this one down, let me know.
why are you suspecting the brake booster hose?
there are so many fragile vacuum lines that are running across the engine top, that are more prone to leaking.
look at the diagram, and follow the lines the best you can.
that should give you a good starting point
Vacuum Confusion -SOLVED
