Old 08-31-2016, 09:12 AM   #2
steved0x
steved0x's Avatar
I used blue/medium on my studs, and haven't had any trouble with them coming loose during wheel changes. Even with red [edit: strike the red, see below] you would be OK when you need to remove the studs (jam two lug nuts together on the stud and remove), although you can leave them on for things like rotor changes and even wheel bearings depending on the method you use to pull the hub (I had to remove 1 of the 5 studs to use the Sir tool puller)
I got these:
M14x1.5 ACS Race Series Studs - M14x1.5 Race Stud - 65mm
M14x1.5 ACS Race Series Studs — Track-Studs.com
If I had it to do over I would have gotten the 80's, the 65's are good, even with spacers up to 7mm (possibly more but 7mm is all I ever tried). I was afraid the 80's would stick out too much and look funny, but after seeing the 65's I don't think the 80's would stik out too far, it is only 15mm more.
These are nice too:
M14x1.5 'Bullet Nose' race stud — Track-Studs.com
If you can find his threads on RL, username apex something, maybe apex competition, he often has a free shipping discount code.
I love my studs, it really does make it easier to change the wheels and I like the look of it too
