Old 08-27-2016, 09:03 AM   #1330
particlewave
Originally Posted by georgewd3 View Post
I've been having some problems with these headlights firing up for a few months now. The problem is this, I start the car and then turn on the headlights. Sometimes they fire right up and gradually brighten but sometimes they don't fire up at all. Last night they fired up, warmed up and I started driving. I was on a back road and hit the high beams. The headlights turned off. Turning the headlight switch on and off didn't do anything. Pulling the high beam switch made a momentary flash but didn't turn the headlights on. I pulled to the side of the road and after fiddling with the switches including the high beam, the lights fired up and then worked perfectly for the drive home.
Any thoughts on what to look for?
Pull the headlight switch and give it a good cleaning by spraying contact cleaner inside of it while switching it back and forth.
