Old 08-26-2016, 05:42 PM   #3
Gelbster
"First - I found nothing on top of the Bellhousing -as shown in the diagram above so perhaps that applies only to older or 5 speed gearboxes??.
1.Underneath the trans , just behind the axle shafts ,on the same side as the shifter,just by the lower counterweight = G86201031713. This is the important #"
This helps others find the easily located number and ignore the rest of the cryptic numbers all over the transmission . Underneath the car on jackstands ,this could be a tedious exercise otherwise.
