			Yes, as Husker said, just be sure to not run the reservoir empty or you could end up with some air in the system that may require cycling of the PSM system to get it out.
 I use a Motive power bleeder and put fluid in the bleeder and let the pressure feed the reservoir. Never had a problem with this process.
				__________________1999 996 C2 - sold - bought back - sold for more
