Old 08-22-2016, 05:08 PM   #4
KevinH1990
KevinH1990's Avatar
This may be a bit of a long shot, but I suggest that you search on the terms "ignition switch" and "cluster" to see if anyone else has had the same problem due to a bad ignition switch. A failed switch can cause some seemingly unrelated problems.
Another possible check is to make sure all of the connectors are seated properly.
