FS: Well-sorted 2001 Boxster S 6spd Black IMS/clutch done
Hi all,
Selling my Box to buy either my first home or a 996tt (yeah, totally brain vs heart).
I have gone through this entire car and it runs great. I drive it all over upstate new york, the finger lakes, the adirondacks without any issues. It will do 145 with the top down on highways in Mexico without a single creak.
I have it listed on Clist for $11.5 for obvious reasons, but would realistically take $10,500k.
Hell of a driver's car here. Pics:
[URL="http://syracuse.craigslist.org/cto/5733642585.html"]
Car Currently has 117,000 miles
- Six speed manual transmission
- 3.2l Flat 6 cylander engine
- Metallic Black Exterior
- Black and Savannah Beige interior
- 6 speaker system with AUX in wired into the factory unit 220
- Litronic Xenon Headlights
- Black Porsche Fitted floor mats
- New Convertible top - OEM A4 Haartz fabric and glass window with rear defrost upgrade (not plastic)
- Ice cold AC
At 113k, it had the following done WITH RECEIPTS at a cost of over $4k:
- LN Engineering Ceramic IMS Bearing
- New OEM Clutch, Flywheel, Pressure pate and ToB
- All 4 new lower control arms
- All 4 new rotors
- Differential Output Seals replaced and Fluid
- Brand new Battery
Since 113k miles:
- Entire Car clay bared and waxed
- front seat removed and carpet cleaned
- all drain holes cleared
- All four tires replaced, mounted and balanced, Hancook Ventus V12 Evo 2s 335/45r17 front and 255/40r17 rear, fronts have less than 1k miles on the, rears about 4k
- rear struts and tower mounts replaced
- 4 wheel alignment at BeeLine in Auburn
- IBC six speed shift knob and boot
- Drive's upstream O2 sensor replaced
- Dash speakers replaced in OEM style
- Electric top transmission arms replaced and top realigned
- All Spark plugs and Tubes replaced with OEM Bosch
- Coolant cap replaced with correct 996.004 replacement
- Clutch switch replaced
- Xenon headlight bulbs replaced
- Removed front bumper and cleaned radiators
- Removed rear bumper and painted rubber bumperettes
- Headlight leveling system replaced
- Throttle body removed and cleaned
Condition:
Interior - Great. Everything looks pretty good. There is a little wear here and there, but nothing that even stands out to note. The dash is perfect.
Exterior - Car is 15 years old. The paint looks good. There are rock chips in the hood, and a few minor scratches here and there and some dings (but no door dings). Overall you will be proud of how the car looks, and it shines up great with a wash and quick wax.
Issues -
1. The cruise control does not work. The light comes on during ignition, but otherwise wont illuminate, I have not tried replacing the brake switch.
2. The passenger side seat electric tilt does not work. I am not sure why this is, but its not in a bad position
Happy to answer any questions about the car, thanks for looking!
