Originally Posted by jamesmcd03
Thanks for the reply. Sorry for my late reply as I wasn't getting alerted to your questions and out of the country.
I have a 2003 Boxster base/stock model - pic attached. - Not sure what you mean by A or B transmission? 5 Speed manual.
Double relay has a black Square painted on the double rely. Pic attached.
What do I do to fix?
Thanks for your help!
The black square indicates that you have the "B Version" convertible top transmissions and set up, which is what was installed at the factory on all MY 2000 to 2004 Boxsters.
Again, because you described a little movement, the first place I would look is at the end of each of the two cables that drive the transmissions. You can check them for length to make sure that they are being driven by the electric motor by first lifting up the upside down U clip that holds them against the sides of the electric motor. If the inner cable is not sticking out by about 1/2 inch from the end of the outer sheath, that is probably your problem. Otherwise, you will have to investigate at the other end of the cables (the transmission end).
Try what I described above and report back.
Regards, Maurice.
