Old 08-18-2016, 10:59 AM   #31
MWS
Originally Posted by TimAustinW View Post
You can easily get thes pocket lids off without disassembling the door. Actually disassembling the door wouldn't buy you anything. Look at the hunges of the pocket lid. Use a small nail punch or even a thick paper clip and push the little hinge rods through. Then you just have to unhook the spring latch. Easy peezy.
Grr.. . Wish I would have thought about this a few years back when I did mine, but I had the door panels off to redo speakers anyway, but good info to know if you did not. I disagree with "disassembling the door won't buy you anything" though, when I had the door apart, it was easy to remove the entire lid/hinge assembly.
Bottom line, if you have the door apart, go ahead and do the lids; if you want to just do the lids, I guess try the method listed above.
