Old 08-18-2016, 09:40 AM   #11
Gelbster
The problem is the same for one hole or one hundred holes - swarf clogging the flutes of the tap .Galling is also a specific problem in aluminum tapping. If you just power-through a galling tap in aliuminum you'll have very loose threads.
Btw fitting a s/s stud +red Loctite instead of a bolt may be a better fix .
