Originally Posted by jscrimsh
Which sensor did you replace? Was it the Coolant sensor found on the bottom drivers side of the engine? I have the same issue and believe its the sensor, but want to make sure before I spend money for parts that have to be ordered...
Do you happen to have an OEM part number as well? When I checked a few parts places, they couldn't do anything without the OEM number.. A few others had the coolant sensor for anywhere from $14-$25. If that's the right sensor, then I figure that's and easy enough thing to do
Mine was the sensor that is found in the engine compartment, not the coolant temp sensor. It sits in a rubber gromet that is snapped in the "spider" on the passenger side of the engine compartment. I can get a part number for the '00 model off of it when I get home if you still need it.
