Flex plate orientation?
With TC pinned in place and tranny bolted up except last 1/8 to 1/4", was planning to bolt flex plate to converter then finish bolting tranny to engine. Problem is, there are no holes in portion of flex plate accessible through starter hole.
Tried rotating engine, thus flex plate, but converter wants to move with it when attempting to rotate. Pins stops rotation. Pulling pin will allow flex plate to rotate, but converter is moving too, so while I can get flex plate holes to appear inside starter hole, when I do, they do not match up with converter, since I had to unpin it to rotate flex plate.
Obviously I've gone wrong somewhere. Trying to understand where. Was there a mark on the flex plate for correct orientation to line up?
Thanks, Joe
