Old 08-01-2016, 12:15 PM   #17
jb92563
jb92563's Avatar
I found that AutoZone actually has a set of Triple Square bits for $15 but they are named stupidly as "OEM 12 point bits".
I confirmed that they are actually Triple Square and will pick them up this evening.
Its been over 100F every day for the last 2 weeks so I'm not too eager to lay under the car for hours.
I have so far put the car up on Jackstands, removed the diagonal braces, pans, heat shields, mufflers and am working on unbolting the drive shafts next.
I'm following the 101Boxster Projects instructions which neatly lists out the proper order to do these things for the best access.
Once I have the transmission out I will be able to see what I need exactly, if its just the clutch or if I need a new flywheel as well.
