Based on you indicating that you have a 03S you likely have the CDR-23 radio and will not need a radio code. Codes are required on 02 or older cars that have a CDR-22 radio. If you do have a CDR-22 a lot of the time the code is hand written on the a white sticker under your frunk lid, which also happens to have your option codes. Good luck.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
