Old 07-25-2016, 11:52 AM   #11
steved0x
steved0x's Avatar
Could it be play at the other end of the tie rod? There is a ball joint there too. Unclear if you replaced the whole tie rod or just the outboard end. Also, If the steering wheel is not immobilized you might get some shake? Have someone sit in the car and hold the wheel? 3rd, there is also a ball joint on the LCA that constrains the movement of the wheel, possibly there is play there?
