Old 06-27-2006, 05:22 AM   #4
insite
Originally Posted by deliriousga
I pulled the MAF and it was pretty dirty. I cleaned it with electronics cleaner and let it dry then put it back in and cranked her up. Still runs crappy and won't accelerate above 2K rpm.
So, before I order a new MAF at $300+ is there anything that comes to mind that I should try first?
TIA!!
if your maf reading was only like 1.4 then you have two possbilities:
1. bad MAF
2. vacuum leak
unplug your MAF and go for a drive. when no MAF signal exists, the car goes into a default map mode. it should run much better than you remember. if that happens, you can bet you need the MAF.
insite
'99 Boxster
3.4L Conversion
http://i156.photobucket.com/albums/t...1/KMTGPR-1.jpg
insite is offline   Reply With Quote
