Old 07-20-2016, 09:54 AM   #3
CrisZenithBlue
CrisZenithBlue's Avatar
i believe the top latch switch is the same, what is different between the two top models is that 2000 and up have a microswitch inside the transmission on the drivers side. The relay is also different but you probably already know that since you converted to the newer model.
if you did not have to change the top latch micro switch when you updated the top i'd say it works fine and they are the same.
CrisZenithBlue is offline   Reply With Quote
