Thread: Pads and fluid
Old 07-18-2016, 05:23 PM   #8
JayG
On the slippery slope
JayG's Avatar
Originally Posted by jsceash View Post
If you intend to run street type tires Dot 140 or higher I'd say try the EBC Red they hold pretty good and are a good match for that grade tires If you run Dot 100 to 60 Use the EBC Yellow. Also a fair match for the capability of the tires. If you start to use Dot 40 or R compound tires look at the Pagid RS-29 yellows.
Of course the price increases in each grade, but I'd try to match the tires and the brakes. Pretty much what I found is the tires in those groupings start to feel greasey before the brakes I suggested. The EBC Yellows will work OK with Dot 40 and R tires but they won't wear well. I get twice the track time from the Pagid on near slicks.
Good luck enjoy it's a fun track day car.
I have run EBC Yellow with both Direzza Star Spec and RE-71 with great results
RedStuff does work well, but I found YellowStuff just felt better
Shop around on Amazon and ebay as well as other websites for the best price.
I bought mine through Summit Racing as they will beat other prices by $1.00 and have great service
If you want the best performing 200TW tires, get Bridgestone RE-71's. They won't last as long as some others, but are faster that other 200TW tires. In my experience they are 2-6 seconds faster than other tires. Hankook RS-3's were the hot tire a few years ago and will last longer than RE-71's, but are not nearly as fast. As Steve mentioned, if you not concerned as much with your run times, RS-3 may be a better value as they will last longer. You will probably heat cycle them out before cording them.
Right now Costco is offering a $70 instant rebate on RE-71's, so they are a great deal. I am ordering a 2nd set
2004 996 Targa Tip
Instructor - San Diego region
