I have the opposite problem where the passenger side will not lock.
When I went to lock my passenger door from the outside, with the key, I discovered that there is NO key slot on that door.
Its probably the locking mechanism in the door, however, if you ever got your CLU under the seat moist or wet then its likely got a problem and needs cleaning/fixing. There is an online company that does that but your car will be down for a couple weeks.
