The codes are for secondary air injection system failures. The SAI system simply injects additional air into the exhaust at cold start for about 90 secs to reduce emissions.
P0410 Secondary Air Injection System, Bank 1 – Below Limit
P1411 Secondary Air Injection System, Bank 2 – Below Limit
Possible cause:
- Secondary air injection pump is not triggered
- Secondary air injection pump does not function
- Air supply lines restricted
- Electric change-over valve does not function
- Air change-over valve does not function
- Vacuum system leaking
Does the engine idle poorly all of the time (cold, hot, etc) or only under certain circumstances?
