FauxD
I suggest you consider removing the seal before you replace the flange.
But first ask the Forum.
The theory is that the grease has gone so if you remove the seal, the IMSB will bet a little oil bath for lubrication.Better than no lubricant.
Some replacement IMSB kits have that seal already removed so it is a reasonable proposition to consider.
