Old 07-15-2016, 04:51 AM   #2
kk2002s
kk2002s's Avatar
Originally Posted by clickman View Post
What are the improvements to the coils since the 9x6 came out of the factory? Why thicker? Ie why not just go with the original style?
I had only pulled one bank and 2 of 3 were cracked
One had a crack into the body but both had cracking around the bolt hole sections
So the thicker design, I think, would be less prone to that. Otherwise I don't know if there is something electronic going on with the thicker
Also It appears a regular 8mm socket will work on these Torx bolts
Even though the plugs I pulled looked excellent after 25000 miles, while I'm in there made sense to replace them.
Seal Grey
