Note that older versions of the detent mod part have been discredited as causing more damage ! So suggest you confirm you get the latest upgrade like the GBox item.
There is also a CMS shift Arrestor that has been discussed on the Forums. You need to really understand exactly what the defect is before you choose either(but not both!) part.
Neither will fix mal-adjusted/worn shifter cable ends.That = new cables
