Old 07-12-2016, 09:22 AM   #13
specboxCO
Well, the tank volume is nominal 64 litres, but i've never got more than 60 litres in.
So half should be around 30 litres and 1/4 around 45 litres to fill. Don't know if the gauge really works linear, because most of the time there is still fuel in the tank even if the gauge says empty.
Regards, Markus
The gauge is very non-liner Below is the calibration I did for my race data system. As you can see when full, a small change in volume creates a large change in voltage, so it is relatively accurate. However when you get to half way, the voltage change is far less, so the accuracy drops considerably. There is a 3v change for the first 30L but only a 0.7v for the last 30L, and only a 0.2v for the last 20L
specboxCO is offline   Reply With Quote
