Thread: 2nd gear issues
Old 07-11-2016, 07:52 PM   #6
thstone
Like the others said, use the stock gear oil. If that does not work it's your 2nd gear synchro.
By the way, notchy shifting can be from a bad motor or transmission mount. If they haven't been replaced yet the rubber is likely bad and this can cause a notchy shift because the trans/engine is moving.
^^^ Very good advice!
