Old 06-26-2016, 09:24 AM   #19
Gelbster
It seems as if the oil is leaking past/over the baffles and starving the oil pick-up tubes ?
If one of the hinged baffles was hanging up ,this is exactly the result that would occur.
Others have reported some mods required to fit the EBS baffle and avoid this and other issues. Did you check this?
EBS Racing oil sump baffle issue - Rennlist Discussion Forums
x51 type baffle that works with deep sump spacer kit
You might investigate "horizontal baffle" also. Tarret/Pedro/Technosump have that as part of their deep sump kit. If positioned correctly, it is very effective.
Gelbster is online now   Reply With Quote
