Old 06-21-2016, 09:08 PM   #5
dghii
Ok. Run 12 Vdc directly to the blower assembly and see if it works. Given the fact that everything else goes away with the blower installed, it may be creating a load that makes the rest of the system inoperable.
If the blower works with 12 volts applied directly, I have no idea what you'd do next but given what you've found so far, you need to determine if your blower is good or bad.
