Originally Posted by steved0x
What camera and mount are you using? I just realized how stable your video is compared with the videos I take. Do you do a processing step to remove shake? If so what do you use?
Thanks,
Steve
Hey Steve, I don't do any preprocessing or anything special, the stability is simply from the camera. The Mobius 1080p camera is impossible to beat for $75.
Mobius Action Camera 1080P
For the mount, I use a RAM dual ball mount with the base attached to the roll bar with a hose clamp. The Mobius cam is controlled (on/off) and powered from the TraqMate/TraqDash data system.
Its a somewhat low-tech setup that works really well. Credit goes to Brad Roberts for the recommendation and installation.
Here is a photo of the mount...
