AOS hack/upgrade Stelan's mod
Great dwg !
Suggest the vac port is moved to the top of the 'catch can' + a dip tube inside.This may avoid sucking condensed oil/fuel vapors into the inlet?
That is the conventional catch can arrangement.
Mounting the new can as high as possible may also help drainage and avoid it getting swamped with liquid oil?
IMHO this drawing is worth using as the basis for a new AOS-mod thread.
