Suggest you read up threads about installing the deep sump and baffles. If you put the horizontal plate-baffle in the wrong place, if the 'windows' jam open ,if the pick-up tubes aren't the right ones - it will be sub-optimal.
It seems the cheaper sump spacer+baffle kits work but only with intelligent fitting & fiddling . The deep sump kits (Mantis/Brey Krause?) seem to work better out-of-the-box.
Need to check your vac system too. An inexpensive paint-can smoker works well.
