Old 06-02-2016, 06:21 AM   #1
jb92563
jb92563's Avatar
When you connect the Durametric the Engine summary page has the DME software version.
What year/model is your car?
No rear O2 sensors? I wonder if that is still a stock setup?
If not, I have seen rear O2 sensor simulator circuits that emulate the signals a rear sensor would produce so that the codes go away.
Or you could install your own by welding a fitting somewhere downstream of the CAT's in the exhaust pipe.
I think the 986's only had the 2 DME versions 5.2 and 7.2 if I recall correctly. Not sure exactly when the transition took place (~2000?) but you will be able to tell from your Durametric readings what you have.
