Old 05-23-2016, 12:26 PM   #38
Smallblock454
Originally Posted by tada View Post
If one of the three injectors is shorting to ground internally, it could cause a failure on all three.
That is correct. OK, pull them an check them.
Maybe they can also be checked if you measure the resistance of the fuel injectors at the ecu - if you diconnect the wiring plug. I don't know the resistance value that should be measured there, but they should be the same as on the other bank.
Regards, Markus
