Old 05-20-2016, 03:32 PM   #4
steved0x
steved0x's Avatar
When the window drops when you open the door but then goes right back up even though the door is still open, that is typically the microsw itch in the door lock assembly.
If it fails to drop when either the outer handle is lifted or the inner handle is lifted, but not both, that is the microswitch for that handle. That switch is available separately
If the window doesn't drop at all, that is usually the regulator.
My passenger side has the door lock assembly issue and my driver side just got it... Uggggg
