Old 05-17-2016, 03:17 AM   #24
rah rah 986
1998 Boxster
Originally Posted by whitecliffs View Post
Is there anyway to test the hydraulic cam followers once there out of the engine, ive got two sets, one set came from a running engine which was nice and quiet, and another set is untested.
Both set are all solid with no movement, is that the way they should be or should there be some spring movement
I'm hoping some one could respond to the op's question and give some clarity. It does seem that lifters removed from a fresh tear down vary in their movement. some have a fair amount of spring travel, and some are completely ridged with oil pressure. Which is correct? And if reassembling the engine, should the lifters be installed without being pre-pumped with oil-allowing full spring travel, or, should they be pre-pumped with oil making them ridged upon reinstalling?
rah rah 986 is offline   Reply With Quote
