Old 05-11-2016, 07:05 AM   #4
jb92563
jb92563's Avatar
Do you hold the button until the top motor stops running?
If the motor stops its because it has contacted the limit switch which shuts it down so you don't burn out the motor.
If the light is not going out after contacting the limit switch then you may have a broken or shorted line/connection from that sensor.
If you hear the motor straining but not stopping then its the limit switch itself.
