Old 05-10-2016, 03:13 PM   #2
steved0x
steved0x's Avatar
Originally Posted by Nitro View Post
... I was puzzled as the wheel hub seems to be "tapered" as it enters the inside half of the bearing. That didn't seem right to me so I got online and started searching for pictures. Sure enough it is not supposed to be that way so now I will need a new wheel hub as well. I can actually push the hub half way into the bearing without using a press!!!
Do you have a picture? That seems odd. My fronts were easier to pull and press the hub than the back, but not like what you describe.
Woody can hook.you up with a hub... New they are freakishly expensive.
