Thread: Door lock ?
Old 05-09-2016, 12:49 PM   #1
jb92563
jb92563's Avatar
I have a Durametric Clone cable that runs version 5 of the software.
In the Alarm section it shows all the codes returned.
Yours should as well, unless you are running old Durametric software on your PC.
You want version 5 or better if its compatible with your cable.
It seems like the codes are not very specific so you just need to focus on the known Door lock with issues and see what you can find.
Moisture under the drivers seat could be an issue for the Alarm module there since it is not moisture resistant and corrosion has been a problem for some.
The door components suffer from things like connector mechanical issues, not making good contact, corrosion, cable chaffing and shorts.
The Door lock itself also has some limit sensors and mechanical components that can fail to function properly.
My drivers side window cables actually came off the pulley due to excessive slack in the system and prevented the window from raising/lowering. The slack came from within the window motor unit in the cable spool.
