Old 05-09-2016, 10:55 AM   #2
steved0x
steved0x's Avatar
At some auto parts stores they sell drain plugs that are very slightly oversized that you can use to tap new threads as you install, and then it has a smaller plug in the middle that you can remove to change the oil, while leaving the larger outer piece that tapped the hole in place. But it hangs down a fair bit. If you are stock and not lowered it shouldn't be a problem. I had to install one on my son's van. You could also do a timesert or a helicoil fix. The only problems with those (and maybe with the one I suggested too) is that some debris from the drilling/tapping might get left up in the sump. You could remove the sump cover relatively easily (if you are doing an oil change the oil is already gone) and tap/repair it, then use Reinzosil to re-seal it up, following the guide on 101Projects.com for the .5 qt deep sump kit.
Maybe you could get a used one from a wrecked Boxster, maybe Woody has one or there are usually a few floating around on eBay.
