Originally Posted by Seadweller
Not to derail, but do these typically fail due to mileage or age?
The usual item that fails is the diaphragm . It splits and is not accessible for diy replacement.
The cause is probably heat cycles/duration. But overfilling with oil or some other way of 'swamping 'the diaphragm is alleged to harm it.
I read of some in no-frost areas,disconnect and bypass the coolant connections on the AOS.
